2019-05-02
カテゴリトップ > アンプ > ブランド名A > Acoustic Image
Acoustic Image 601IA plus Clarus 2 plus 2ch 600W integraged Amp w/Effects《アンプ》【送料無料】【次回入荷分ご予約受付中】
Specification
Extended frequency range, high fidelity sound
Light weight (<4 lbs.), small size (10.2 x 8.2 x 3.5)
Unique, slanted front chassis
Mounts in cabinet using Cabrio Docking System
Separate XLR and 1/4 inch inputs in each channel can be used simultaneously
48V phantom power and 10 dB gain select for mic input
Input level control per channel
Four band EQ per channel
Selectable phase reverse and sweepable low cut filter per channel (phase reverse can be converted to low pass speaker emulation filter with internal jumper option)
Effects loop per channel
Selectable reverb and delay effects with level and rate controls and pseudo stereo output
Direct out with selectable 10 dB pad, pre/post switch and ground lift-Headphone output
Switchable limiter
Mute switch
Mono or stereo output from the preamp section
Selectable internal jumper options for gain and stereo operation
High fidelity, low noise operation: 110 dB SNR at direct out
Automatic voltage switching for universal AC mains operation
650 Watt output at 4 ohms (music power)
Dual speaker outputs with speakon connectors
Comes with padded case and speakon to ? inch adaptor
 【アンプ】《アコースティックイメージ》
140,000円 (税込 151,200 円)
次回入荷分。納期は別途ご連絡いたします。
※注文個数によりお届け日が変わることがあります。
