Guide to Flux Core Welding (FCAW)
WeldGuru-slider02
WeldGuru-slider01
Flux Core Arc Welding (FCAW) uses a tubular wire that is filled with a flux. The arc is initiated between the continuous wire electrode and the workpiece. The flux, which is contained within the core of the tubular electrode, melts during welding and shields the weld pool from the atmosphere. Direct current, electrode positive (DCEP) is commonly employed as in the FCAW process.
There are two basic process variants; self shielded FCAW (without shielding gas) and gas shielded FCAW (with shielding gas). The difference in the two is due to different fluxing agents in the consumables, which provide different benefits to the user. Usually, self-shielded FCAW is used in outdoor conditions where wind would blow away a shielding gas. The fluxing agents in self shielded FCAW are designed to not only deoxidize the weld pool but also to allow for shielding of the weld pool and metal droplets from the atmosphere.
The flux in gas-shielded FCAW provides for deoxidation of the weld pool and, to a smaller degree than in self-shielded FCAW, provides secondary shielding from the atmosphere. The flux is designed to support the weld pool for out-of position welds. This variation of the process is used for increasing productivity of out-of-position welds and for deeper penetration.
Hi, my name is Garrett… (owner of weldguru.com)
For the past 5 years I’ve helped well over 10,000 beginners and hobbyists get started learning to mig weld through my free training. If you’d like to get started, Download my FREE beginner’s guide to MIG welding.
Flux Cored Self Shielded Welding
Miller Electric
Process
Flux core welding or tubular electrode welding has evolved from the MIG welding
process to improve arc action, metal transfer, weld metal properties,
and weld appearance. It is an arc welding process in which the heat for
welding is provided by an arc between a continuously fed tubular
electrode wire and the workpiece. Shielding is obtained by a flux
contained within the tubular electrode wire or by the flux and an
externally supplied shielding gas. A diagram of the process is shown in figure 10-55 below.
The flux-cored welding wire, or electrode, is a hollow tube filled with a
mixture of deoxidizers, fluxing agents, metal powders, and
ferro-alloys. The closure seam, which appears as a fine line, is the
only visible difference between flux-cored wires and solid cold-drawn
wire. Flux-cored electrode welding can be done in two ways: carbon
dioxide gas can be used with the flux to provide additional shielding,
or the flux core alone can provide all the shielding gas and slagging
materials. The carbon dioxide gas shield produces a deeply penetrating
arc and usually provides better weld than is possible without an
external gas shield. Although flux-cored arc welding may be applied
semiautomatically, by machine, or automatically, the process is usually
applied semiautomatically.
In semiautomatic welding, the wire feeder
feeds the electrode wire and the power source maintains the arc length.
The welder manipulates the welding gun and adjusts the welding
parameters. Flux-cored arc welding is also used in machine welding
where, in addition to feeding the wire and maintaining the arc length,
the machinery also provides the joint travel. The welding operator
continuously monitors the welding and makes adjustments in the welding
parameters. Automatic welding is used in high production applications.
Flux Cored Welding Process Diagram - figure 10-55
Welding Tips
  • Do not use smooth wire drive rolls, use the knurled drive rolls
  • Change polarity to electrode negative (check with manufacturer, MIG is usually electrode positive)
  • Use adequate ventilation
  • 1/2" to 3/4" wire stick out
  • Drag the gun (backhand weld)
  • For flat weld, weld at 90 degrees and 10 degrees back. T Joint at 45 degrees.  Lap joint at 60 degrees to 70 degrees with one straight weld. For horizontal angle gun upwards at around 10 degrees, turn welding parameters on machine down about 10 to 15%. For vertical weld (can use up or down, vertical down is better for thinner metals, us vertical up for 1/4" and above,  also turn parameters down 10 to 15% on machine. For overhead try and maintain a fast travel speed and also reduce welding parameters by 10% to 15% (as compared to flat or horizontal weld).
  • Weld side to side to avoid undercut
  • Thoroughly clean off slag after each pass
FCAW vs. GMAW and SMAW
The FCAW flux core process combines the best
characteristics of SMAW and GMAW. It uses a flux to shield the weld pool,
although a supplemental shielding gas can be used. A continuous wire electrode
provides high deposition rates.
FCAW vs GMAW:
Flux-cored arc welding is similar to gas metal arc welding (GMAW or MIG) in many ways.
The flux-cored wire used for this process gives it different
characteristics. Flux-cored arc welding is widely used for welding
ferrous metals and is particularly good for applications in which high
deposition rates are needed. At high welding currents, the arc is smooth
and more manageable when compared in using large diameter gas metal arc
welding electrodes with carbon dioxide. The arc and weld pool are
clearly visible to the welder. A slag coating is left on the surface of
the weld bead, which must be removed. Since the filler metal transfers
across the arc, some spatter is created and some smoke produced.
The flux for FCAW consumables can
be designed to support larger weld pools out of position and provide higher
penetration compared to using a solid wire (GMAW). Larger welds can be made in
a single pass with larger diameter electrodes where GMAW and SMAW would need
multiple passes for equivalent weld sizes. This improves productivity and
reduces distortion of a
weldment.
If you're new to MIG welding and you'd like a simple training so you can learn quickly, without the headaches, Download my FREE beginner’s guide to MIG welding.
FCAW vs SMAW
As with SMAW, the slag must be
removed between passes on
multipass
welds. This can slow down the productivity of the application and result in
possible slag inclusion discontinuities. For gas shielded FCAW, porosity can
occur as a result of insufficient gas coverage.
Large amounts of fume are produced
by the FCAW process due to the high currents, voltages, and the flux inherent
with the process.  Increased costs could
be incurred through the need for ventilation equipment for proper health and
safety.
FCAW is more complex and more
expensive than SMAW because it requires a wire feeder and welding gun. The
complexity of the equipment also makes the process less portable than SMAW.
Equipment
Flux Cored Welding Equipment
Shown:
SUNGOLDPOWER MIG 150A Welder Flux Core Wire Automatic Feed Welding AC Welder Gasless Machine Free Mask NO Gas
.. Supports Stick (SMAW), MIG (GMAW, Flux Cored (FCAW), DC TIG (DC GTAW), AC TIG (AC GTAW), Air Carbon Arc (CAC-A) Cutting and Gouging
The equipment used for flux core arc welding is similar to that used
for gas metal arc welding. The basic arc welding equipment consists of a
power source, controls, wire feeder, welding gun, and welding cables. A
major difference between the gas shielded electrodes and the
self-shielded electrodes is that the gas shielded wires also require a
gas shielding system. This may also have an effect on the type of
welding gun used. Fume extractors are often used with this process. For
machines and automatic welding, several items, such as seam followers
and motion devices, are added to the basic equipment.
Diagram of Semiautomatic Flux-cored Arc Welding Equipment - figure 10-56
Power Source
The power source, or welding machine, provides the electric power of
the proper voltage and amperage to maintain a welding arc. Most power
sources operate on 230 or 460 volt input power, but machines that
operate on 200 or 575 volt input are also available. Power sources may
operate on either single phase or three-phase input with a frequency of
50 to 60 hertz. Most power sources used for flux-cored arc welding have a
duty cycle of 100 percent, which indicates they can be used to weld
continuously. Some machines used for this process have duty cycles of 60
percent, which means that they can be used to weld 6 of every 10
minutes. The power sources generally recommended for flux-cored arc
welding are direct current constant voltage type. Both rotating
(generator) and static (single or three-phase transformer-rectifiers)
are used. The same power sources used with gas metal arc welding are
used with flux-cored arc welding. Flux-cored arc welding generally uses
higher welding currents than gas metal arc welding, which sometimes
requires a larger power source. It is important to use a power source
that is capable of producing the maximum current level required for an
application.
Direct Current Process
Flux-cored arc welding uses direct current. Direct current can be
either reverse or straight polarity. Flux-cored electrode wires are
designed to operate on either DCEP or DCEN. The wires designed for use
with an external gas shielding system are generally designed for use
with DCEP. Some self-shielding flux-cored ties are used with DCEP while
others are developed for use with DCEN. Electrode positive current gives
better penetration into the weld joint. Electrode negative current
gives lighter penetration and is used for welding thinner metal or
metals where there is poor fit-up. The weld created by DCEN is wider and
shallower than the weld produced by DCEP.
The generator welding machines used for the flux core process can be
powered by an electric rotor for shop use, or by an internal combustion
engine for field applications. The gasoline or diesel engine-driven
welding machines have either liquid or air-cooled engines. Motor-driven
generators produce a very stable arc, but are noisier, more expensive,
consume more power, and require more maintenance than
transformer-rectifier machines.
Wire Feed Motor
A wire feed motor provides power for driving the electrode
through the cable and gun to the work. There are several different wire
feeding systems available. System selection depends upon the
application. Most of the wire feed systems used for flux-cored arc
welding are the constant speed type, which are used with constant
voltage power sources. With a variable speed wire feeder, a voltage
sensing circuit is used to maintain the desired arc length by varying
the wire feed speed. Variations in the arc length increase or decrease
the wire feed speed. A wire feeder consists of an electrical rotor
connected to a gear box containing drive rolls. The gear box and wire
feed motor shown in figure 10-57 have form feed rolls in the gear box.
FCAW Wire Feed Assembly - figure 10-57
Air and Water Cooled Welding Guns
Both air-cooled and water-cooled guns are used for flux-cored arc
welding. Air-cooled flux core guns are cooled primarily by the surrounding air,
but a shielding gas, when used, provides additional cooling effects. A
water-cooled gun has ducts to permit water to circulate around the
contact tube and nozzle. Water-cooled flux core guns permit more efficient cooling
of the gun. Water-cooled guns are recommended for use with welding
currents greater than 600 amperes, and are preferred for many
applications using 500 amperes. Welding guns are rated at the maximum
current capacity for continuous operation. Air-cooled guns are preferred
for most applications less than 500 amperes, although water-cooled guns
may also be used. Air-cooled guns are lighter and easier to manipulate.
Shielding Gases
Shielding gas equipment used for gas shielded flux-cored wires
consists of a gas supply hose, a gas regulator, control valves, and
supply hose to the welding gun. (as noted above flux core can be used without shielding gas depending on the application)
The shielding gases are supplied in liquid form when they are in
storage tanks with vaporizers, or in a gas form in high pressure
cylinders. An exception to this is carbon dioxide. When put in high
pressure cylinders, it exists in both liquid and gas forms.
The primary purpose of the shielding gas is to protect the arc
and weld puddle from contaminating effects of the atmosphere. The
nitrogen and oxygen of the atmosphere, if allowed to come in contact
with the molten weld metal, cause porosity and brittleness. In
flux-cored arc welding, shielding is accomplished by the decomposition
of the electrode core or by a combination of this and surrounding the
arc with a shielding gas supplied from an external source. A shielding
gas displaces air in the arc area. Welding is accomplished under a
blanket of shielding gas. Inert and active gases may both be used for
flux-cored arc welding. Active gases such as carbon dioxide,
argon-oxygen mixture, and argon-carbon dioxide mixtures are used for
almost all applications. Carbon dioxide is the most common. The choice
of the proper shielding gas for a specific application is based on the
type of metal to be welded, arc characteristics and metal transfer,
availability, cost of the gas, mechanical property requirements, and
penetration and weld bead shape. The various shielding gases are summarized below.
  1. Carbon dioxide: Carbon
    dioxide is manufactured from fuel gases which are given off by the
    burning of natural gas, fuel oil, or coke. It is also obtained as a
    by-product of calcining operation in lime kilns, from the manufacturing
    of ammonia and from the fermentation of alcohol, which is almost 100
    percent pure. Carbon dioxide is made available to the user in either
    cylinder or bulk containers. The cylinder is more common. With the bulk
    system, carbon dioxide is usually drawn off as a liquid and heated to
    the gas state before going to the welding torch. The bulk system is
    normally only used when supplying a large number of welding stations. In
    the cylinder, the carbon dioxide is in both a liquid and a vapor form
    with the liquid carbon dioxide occupying approximately two thirds of the
    space in the cylinder. By weight, this is approximately 90 percent of
    the content of the cylinder. Above the liquid, it exists as a vapor gas.
    As carbon dioxide is drawn from the cylinder, it is replaced with
    carbon dioxide that vaporizes from the liquid in the cylinder and
    therefore the overall pressure will be indicated by the pressure gauge.
    When the pressure in the cylinder has dropped to 200 psi (1379 kPa), the
    cylinder should be replaced with a new cylinder. A positive pressure
    should always be left in the cylinder in order to prevent moisture and
    other contaminants from backing up into the cylinder. The normal
    discharge rate of the CO2 cylinder is about 10 to 50 cu ft
    per hr (4.7 to 24 liters per min). However, a maximum discharge rate of
    25 cu ft per hr (12 liters per min is recommended when welding using a
    single cylinder. As the vapor pressure drops from the cylinder pressure
    to discharge pressure through the CO2 regulator, it absorbs a
    great deal of heat. If flow rates are set too high, this absorption of
    heat can lead to freezing of the regulator and flowmeter which
    interrupts the shielding gas flow. When flow rate higher than 25 cu ft
    per hr (12 liters per min) is required, normal practice is to manifold
    two CO2 cylinders in parallel or to place a heater between
    the cylinder and gas regulator, pressure regulator, and flowmeter.
    Excessive flow rates can also result in drawing liquid from the
    cylinder. Carbon dioxide is the most widely used shielding gas for
    flux-cored arc welding. Most active gases cannot be used for shielding,
    but carbon dioxide provides several advantages for use in welding steel.
    These are deep penetration and low cost. Carbon dioxide promotes a
    globular transfer. The carbon dioxide shielding gas breaks down into
    components such as carbon monoxide and oxygen. Because carbon dioxide is
    an oxidizing gas, deoxidizing elements are added to the core of the
    electrode wire to remove oxygen.The oxides formed by the deoxidizing
    elements float to the surface of the weld and become part of the slag
    covering. Some of the carbon dioxide gas will break down to carbon and
    oxygen. If the carbon content of the weld pool is below about 0.05
    percent, carbon dioxide shielding will tend to increase the carbon
    content of the weld metal. Carbon, which can reduce the corrosion
    resistance of some stainless steels, is a problem for critical corrosion
    application. Extra carbon can also reduce the toughness and ductility
    of some low alloy steels. If the carbon content in the weld metal is
    greater than about 0.10 percent, carbon dioxide shielding will tend to
    reduce the carbon content. This loss of carbon can be attributed to the
    formation of carbon monoxide, which can be trapped in the weld as
    porosity deoxidizing elements in the flux core reducing the effects of
    carbon monoxide formation.Argon-carbon dioxide mixtures.
  2. Argon and carbon dioxide are
    sometimes mixed for use with flux-cored arc welding. A high percentage
    of argon gas in the mixture tends to promote a higher deposition
    efficiency due to the creation of less spatter. The most commonly used
    gas mixture in flux-cored arc welding is a 75 percent argon-25 percent
    carbon dioxide mixture. The gas mixture produces a fine globular metal
    transfer that approaches a spray. It also reduces the amount of
    oxidation that occurs, compared to pure carbon dioxide. The weld
    deposited in an argon-carbon dioxide shield generally has higher tensile
    and yield strengths. Argon-carbon dioxide mixtures are often used for
    out-of-position welding, achieving better arc characteristics. These
    mixtures are often used on low alloy steels and stainless steels.
    Electrodes that are designed for use with CO2 may cause an
    excessive buildup of manganese, silicon, and other deoxidizing elements
    if they are used with shielding gas mixtures containing a high
    percentage of argon. This will have an effect on the mechanical
    properties of the weld.
  3. Argon-oxygen mixtures: Argon-oxygen mixtures containing 1
    or 2 percent oxygen are used for some applications. Argon-oxygen
    mixtures tend to promote a spray transfer which reduces the amount of
    spatter produced. A major application of these mixtures is the welding
    of stainless steel where carbon dioxide can cause corrosion problems.
Electrodes
Cross Section of Flux Core Wire - figure 10-58
The electrodes used for flux-cored arc welding provide the filler metal
to the weld puddle and shielding for the arc. Shielding is required for
sane electrode types. The purpose of the shielding gas is to provide
protection from the atmosphere to the arc and molten weld puddle. The
chemical composition of the electrode wire and flux core, in combination
with the shielding gas, will determine the weld metal composition and
mechanical properties of the weld. The electrodes for flux-cored arc
welding consist of a metal shield surrounding a core of fluxing and/or
alloying compounds as shown in figure 10-58.
The cores of carbon steel and low alloy electrodes contain primarily
fluxing compounds. Some of the low alloy steel electrode cores contain
high amounts of alloying compounds with a low flux content. Most low
alloy steel electrodes require gas shielding. The sheath comprises
approximately 75 to 90 percent of the weight of the electrode.
Self-shielded electrodes contain more fluxing compounds than gas
shielded electrodes. The compounds contained in the electrode perform
basically the same functions as the coating of a covered electrode used
in shielded metal arc welding.
These functions are:
  1. To form a slag coating that floats on the surface of the weld metal and protects it during solidification.
  2. To provide deoxidizers and scavengers which help purify and produce solid weld-metal.
  3. To provide arc stabilizers which produce a smooth welding arc and keep spatter to a minimum.
  4. To add alloying elements to the weld metal which will increase the strength and improve other properties in the weld metal.
  5. To provide shielding gas. Gas shielded wires require an
    external supply of shielding gas to supplement that produced by the core
    of the electrode.
Classification System for Tubular Wire Electrodes
The classification system used for tubular wire electrodes used as part of flux core welding was
devised by the American Welding Society. Carbon and low alloy steels are
classified on the basis of the following items:
  1. Mechanical properties of the weld metal.
  2. Welding position.
  3. Chemical composition of the weld metal.
  4. Type of welding current.
  5. Whether or not a CO2 shielding gas is used.
An example of a carbon steel electrode classification is E70T-4 where:
  1. The "E" indicates an electrode.
  2. The second digit or "7" indicates the minimum tensile strength in units of 10,000 psi (69 MPa).
  3. The third digit or "0" indicates the welding positions. A "0"
    indicates flat and horizontal positions and a "1" indicates all
    positions.
    4. The "T" stands for a tubular or flux cored wire classification.
    5. The suffix "4" gives the performance and usability capabilities as shown in table 10-13.  When a "G" classification is used, no specific performance and
    usability requirements are indicated. This classification is intended
    for electrodes not covered by another classification. The chemical
    composition requirements of the deposited weld metal for carbon steel
    electrodes are shown in table 10-14.Single pass electrodes do not have chemical composition requirements
    because checking the chemistry of undiluted weld metal does not give the
    true results of normal single pass weld chemistry.
Carbon Flux Steel Electrodes
Mechanical Property Requirements of Carbon Steel Flux-Cored Electrodes - Table 10-12
The mechanical property requirements for the various carbon steel electrodes
* as agreed upon between user and supplier
Performance and Usability Characteristics of Carbon Steel Flux Cored Electrodes - Table 10-13
Chemical Composition Requirements of Carbon Steel Flux Cored Electrodes - Table 10-14
The classification of low alloy steel electrodes used in flux core welding is similar to the
classification of carbon steel electrodes. An example of a low alloy
steel classification is E81T1-NI2 where:
  1. The "E" indicates electrode.
  2. The second digit or "8" indicates the minimum tensile in
    strength in units of 10,000 psi (69 MPa). In this case it is 80,000 psi
    (552 MPa). The mechanical property requirements for low alloy steel
    electrodes are shown in table 10-15. Impact strength requirements are shown in table 10-16.
  3. The third digit or "1" indicates the welding position capabilities of
    the electrode. A "1" indicates all positions and an "0" flat and
    horizontal position only.
  4. The "T" indicates a tubular or flux-cored electrode used in flux cored arc welding.
  5. The fifth digit or "1" describes the usability and
    performance characteristics of the electrode. These digits are the same
    as used in carbon steel electrode classification but only EXXT1-X,
    EXXT4-X, EXXT5-X and EXXT8-X are used with low alloy steel flux-cored
    electrode classifications.
  6. 6. The suffix or "Ni2" tells the chemical composition of the deposited weld metal as shown in table 10-17 below.
Mechanical Property Requirements of Low Alloy Flux-Cored Electrodes - Table 10-15
Impact Requirements For Low Alloy Flux Cored Electrodes - Table 10-16
Chemical Composition Requirements for Low Alloy Flux-Cored Electrodes - Table 10-17 (chemical composition percent (a)
a. Single values are maximum unless otherwise noted
b. For self-shielded electrodes only
c. In order to meet the alloy requirements of the G group, the weld deposit have the minimum, as specific in the table of only one of the elements
d. The E80TI-W classification also contains .30 - .75 percent copper
Stainless Steel Electrodes
The classification system for stainless steel electrodes used in flux core welding  is based on
the chemical composition of the weld metal and the type of shielding to
be employed during welding. An example of a stainless steel electrode
classification is E308T-1 where:
  1. The "E" indicates the electrode.
  2. The digits between the "E" and the "T" indicates the chemical composition of the weld as shown in table 10-18 below.
  3. The "T" designates a tubular or flux cored electrode wire.
  4. The suffix of "1" indicates the type of shielding to be used as shown in table 10-19 below.
Weld Metal Chemical Composition Requirements for Stainless Steel Electrodes - Table 10-18
Shielding - Table 10-19
Welding Cables
The welding cables and connectors are used to connect the power
source to the welding gun and to the work. These cables are normally
made of copper. The cable consists of hundreds of wires that are
enclosed in an insulated casing of natural or synthetic rubber. The
cable that connects the power source to the welding gun is called the
electrode lead. In semiautomatic welding, this cable is often part of
the cable assembly, which also includes the shielding gas hose and the
conduit that the electrode wire is fed through. For machine or automatic
welding, the electrode lead is normally separate. The cable that
connects the work to the power source is called the work lead. The work
leads are usually connected to the work by pinchers, clamps, or a bolt.
The size of the welding cables used depends on the output
capacity of the flux core welding machine, the duty cycle of the machine, and the
distance between the welding machine and the work. Cable sizes range
from the smallest AWG No 8 to AWG No 4/0 with amperage ratings of 75
amperes on up.
Table 10-20 shows recommended cable sizes for use with different welding currents
and cable lengths. A cable that is too small may become too hot during
welding.
Recommended Cable Sizes for Different Welding Currents - Table 10-20
Pros and Cons
Advantages: Reduced Cost and Higher Deposition
  • High
    deposition rates
  • Deeper
    penetration than  SMAW
  • High-quality
  • Less
    pre-cleaning than GMAW
  • Slag
    covering helps with larger out-of-position welds
    Self-shielded FCAW is draft tolerant
The major advantages of flux core welding are reduced cost and higher
deposition rates than either SMAW or solid wire GMAW. The cost is less
for flux-cored electrodes because the alloying agents are in the flux,
not in the steel filler wire as they are with solid electrodes.
Flux-cored welding is ideal where bead appearance is important and no
machining of the weld is required. Flux-cored welding without carbon
dioxide shielding can be used for most mild steel construction
applications. The resulting welds have higher strength but less
ductility than those for which carbon dioxide shielding is used. There
is less porosity and greater penetration of the weld with carbon dioxide
shielding. The flux-cored process has increased tolerances for scale
and dirt.
There is less weld spatter for flux core welding than with solid-wire MIG welding.
It has a high deposition rate, and faster travel speeds are often used.
Using small diameter electrode wires, welding can be done in all
positions. Some flux-cored wires do not need an external supply of
shielding gas, which simplifies the equipment. The electrode wire is fed
continuously so there is very little time spent on changing electrodes.
A higher percentage of the filler metal is deposited when compared to
shield metal arc welding. Finally, better penetration is obtained than
from shielded metal arc welding.
Disadvantages: Sensitivity to Welding Conditions
Flux core welding disadvantages summary:
  • Slag
    must be removed
    smoke and fumes than GMAW and SAW
  • Spatter
  • FCAW
    wire is more expensive
  • Equipment
    is more expensive and complex than for SMAW
Most low-alloy or mild-steel electrodes of the flux-cored type are more
sensitive to changes in welding conditions than are SMAW electrodes.
This sensitivity, called voltage tolerance, can be decreased if a
shielding gas is used, or if the slag-forming components of the core
material are increased. A constant-potential power source and
constant-speed electrode feeder are needed to maintain a constant arc
voltage.
FCAW Troubleshooting
When troubleshooting flux core welds, be sure to check the manufacturers directions (found inside the equipment panel) for the following (described in detail below):
  • Wire Feed Speed
  • Travel Speed
  • Contact Tip to Work Distance
  • Feeder Polarity
  • Work angle and travel angle
FCAW Troubleshooting Video
Author: Lincoln Electric
  • Too Low Of a Wire Feed Feed and Current (higher speeds = higher current, lower speeds, lower current: If the speed is too low, you will not get complete coverage, a narrow beed and alot of spatter.
FCAW Weld Created At Low Wire Speed
Low wire speed for FCAW weld resulted in hard to remove slag and a lot of spatter.
  • If wire speed is too high the wire will keep stubbing. To fix turn voltage up or wire speed down.
FCAW Weld Created At High Wire Speed
  • Travel speed too slow:  result is a convex wide weld. The slag doesn't cover properly.
FCAW Weld With Low Travel Speed
  • Travel speed faster than what is recommended: results in a narrow convex weld bead.  Compare to too flow travel speed above vs. outrunning puddle below.
FCAW Weld With Fast Travel Speed
  • Contact tip to work distance: Check correct distance for your wire. Too short distance results in inadequate coverage due to the improper preheating of the flux inside the wire.  The slag does not cover the entire weld making the slag look dark down the center of the weld.If the distance is too far, there will be some stubbing of the weld.  The wire looks like it is hunting for the weld, makes the feeding inconsistent causing ripples in the weld.
FCAW Contact Tip to Work Distance Troubleshooting
Contact tip to work distance is too far (top) and too short (bottom). Check manufacturers directions for correct distance (usually 1/2" to 5/8")
  • Polarity: each wire has recommended polarity. Sometimes DC negative is used when DC positive is needed.  Causes spatter and a small weld.
FCAW Polarity Troubleshooting
Spatter due to wrong polarity. Make Sure that You are Using the Correct Polarity when Flux Core Welding. Do not use DC Positive if DC Negative is Required. Check Diagram of Machine Setup. Check how Feeder is Connected to Welding Equipment.
FCAW Polarity Feeder Polarity
Make Sure the Feeder is Connected to the Correct Poles. Review Diagram inside of Equipment Panel
  • Electrode Angles: For flux core remember that there is slag you drag. Make sure that you drag the electrode to allow the slag to form behind the weld. It is lighter than the molten puddle and it will float to the top. If you push it you chance getting slag inclusions in the weld.
  • Check the work and travel angle: If welding on a flat surface, the angle could be 90 degrees. For a lap joint or T joint you want to be 45 degrees to the joint and a 5 to 10 degrees for the drag.
For Additional Reading
Free Flux Core Arc Welding Handbook:
Flux Cored Arc Welding (PDF Download)
Helpful Online References:
Fluxed Core Welding Basics
Welding Calculator For Settings
