You are here
Home > Welding School > Biggest Weld Ever?
Biggest Weld Ever?
Hi Garret , thanks for your videos , they are quite interesting .
I don’t have a mig welder but do plenty of stick welding and enjoy it when I get a great result . Some years ago I purchased a real old Miller welder that can do both Ac and dc welding , wow how much better it is using dc over Ac .
Your videos are great to help a person new to welding and I am pleased that you have done them as they are easy to understand .
Thanks again!
I attached a pic of one of my biggest welds ever…
A repair to a cast steel plate around 18″ diameter . I lathed out the crack , preheated the whole thing then applied more heat to the outside of the plate then did the weld …. About 4 kg of rods !
I learned how to do this from a unequaled engineer who is well into his eighties. And has forgotten more than most modern engineers will ever know!
A very successful result and no warping pulling Or cracks !
Thanks and best regards, Tim
One thought on “Biggest Weld Ever?
  1. 2 × 40mm single V-preps with 40mm fillet 600mm vertical up pre-heated to 240deg. 6 passes short of completion at the end of a 12 hour night shift.
    Sorry no photos, Supervisor dragged me away as the bus was waiting for me.
Top
