You are here
Home > Uncategorised > How To Choose The Right Welder
When it comes to selecting an appropriate welder to handle your everyday projects, you ought to be extremely cautious. Whether you weld as a hobby or as a full-time occupation, it’s crucial to choose the best welder that will fulfill your needs without causing unwanted inconveniences. For instance, here are the Best Plasma Cutters that are currently on the market.
Let’s discuss 4 factors you need to consider when choosing the right welder:
  1. Type of welding job
Before buying a welder, ask yourself: what is the nature of my job? How frequently will I be using a welder in my line of work? If the usage is limited to a couple of times annually, then it’s probably better to rent a welding machine rather than buying one. But if you’ll be using it on a regular, then conduct some prior research to determine what type of welder you need. Every welding machine has wide-ranging benefits and restrictions. For instance, most welding experts find MIG machines to be versatile and easy to operate compared to their TIG counterparts.
  1. Consider the type of welder
There exists a raging debate on which welder works better between MIG (Metal Inert Gas) and TIG (Tungsten Inert Gas) welders. First off, it’s important to note that MIG welders enjoy more popularity since they’re less costly than Stick or TIG welders. MIG varieties are also quite easy to learn, allowing beginners to quickly get the hang of it. MIG welders are versatile as well, meaning they’re able to handle a wider array of projects compared to other varieties.
TIG welders, on the other hand, can easily weld together extra thin materials because of their incredible accuracy. They utilize precision control and rely on a concentrated heat source – TIGs are perfect for those who require high levels of precision craftsmanship. Finally, stick welders are suitable for welding most materials, but with less precision. However, these welders can’t be used in overhead positions.
  1. Determine the welding speed
Apart from precision, you ought to think about the welding speed. If you’re using a stick welder, the entire welding process will be relatively slower compared to using a MIG or TIG welder. Also known as Shielded Metal Arc Welding, the stick welders utilize electrodes that contain cast iron, steel or another suitable alloy. The greatest benefit you can accrue when using stick welders is the aspect of welding those hard-to-reach areas. However, the welding process is quite slow. MIG, on the other hand, is suitable for deep weld penetration and welds faster than stick welders.
  1. Think about the duty cycle
Most seasoned welders might be familiar with the term “duty cycle” which generally refers to the average runtime of a particular welding machine before it requires a little time out so it can cool off. Expensive varieties boast of having longer duty cycles while cheaper welders have surprisingly short duty cycles. If you’re welding thick materials together, you’ll need to purchase a welder possessing a lengthy duty cycle. This might cause you to dig deeper into your pockets, but the investment will be worthwhile.
Consider these factors when choosing the right welder for you.
Top
