You are here
Home > All Things Metal > IBOAT360 Imperial Blades Carbide Extreme Blade
Mess up a weld seam? Need to cut thick metals or make adjustments?
Don’t want to start over?
Well good news, the Imperial Blades IBOAT360 Carbide Extreme Metal BladeĀ
is here to save the day – designed with a 1/8″ Carbide Strip attached to the bottom of the blade – this will continue cutting metals even as the teeth wear out.
This blade is an absolute must for remodeling, demo jobs, and for welders looking to make cuts into steel, aluminum, and copper.
LEAVE US A COMMENT BELOW AND BE ENTERED TO WIN $100!!!
7 thoughts on “IBOAT360 Imperial Blades Carbide Extreme Blade
Top
