110-volt stick welders are cheap and you can plug them into any regular wall socket. They’re mainly for small projects at home or around the farm.
You’ll never get great power output on 110V; however, you want a machine that will output power the best it can.
While it wasn’t possible to test all the 110V stick machines on the market, I used my experience with the machines I have used, as well as some help from some fellow welders.
When choosing the best options, I looked for:
- Good power output with 110V input
- How it handles different rods
- Machine build quality
- Brand reliability and support
- Overall user satisfaction
My personal favorite is the Hobart Stickmate 160i, which ticks all the boxes above and is excellent value for money if you’re comparing it to a brand name like Miller.
Note: I purposefully avoided the cheapest Chinese stick welders as I have had bad experiences with them. They are usually unreliable, the parts are hard to find, or their support is non-existent.
With that in mind, let’s dive in.
| Product | |||
Hobart Stickmate 160i |
Excellent performance to price ratio on 110V Good with 6010 rods A favorite among DIYers |
YesWelder Arc Pro 165A |
Consistant output for a cheap stick welder Auto settings helps newbies 6013 & 7014 rods work well on 110V |
Forney Easy Weld 100ST |
Super lightweight & compact Handles 6013 with ease on 110V Great value for money |
Miller Maxstar 161 S |
Must buy if you want to run 6010s Superior build quality Anti-sticking feature |
Best 110v Stick Welders
Here's a list of some of the best 110v stick welders I recommend:
1. Hobart Stickmate 160i 110v Stick Welder
- Dual 110v/240v input power
- 24-gauge to 1/4-inch steel
- DC stick welder
- 160 amps max output
- 5-year warranty
- Hot Start for easy striking
- Lightweight 20 pounds
- 20-160 amp range
- Infinitely adjustable current
- Includes shoulder strap
- American brand, but made in China
- Top of this price range
The Hobart Stickmate 160i is one of the most popular stick welders for hobbyists. It’s a dual-voltage machine, but the 110V output is pretty impressive. It’s not as good as the Miller Maxstar in terms of output performance and arc stability, which is more for farm work. However, it does represent the best value for money for most people who need a stick welder.
There is a lot to like about this machine, including a weight under 20 pounds, an included shoulder strap, and the ability to run most rod compositions that matter. The Hobart Stickmate 160i handles 6010, 6011, 6013, and 7018 rods by most makers.
The Hobart Stickmate 160i features an infinitely adjustable amps setting, and it works well on metal from 24 gauge sheet up to 1/4-inch thick. Hobart machines are known for industrial build quality and smooth welding. This model delivers in that regard and Hobart backs the Stickmate 160i with a 5-year warranty.
This particular model is made for Hobart in China, something to think about if you want a genuine American-made machine by an American maker. It’s built and inspected to meet Hobart standards, however.
2. YesWelder Arc Pro 165A Stick Welding Machine
- Self-setting by rod diameter
- Dual-powered on 110v and 240v
- Lift-TIG capable (needs parts)
- VRD voltage-reduction device
- Synergic welding technology
- Runs well on 110V with 6013 & 7014 rods
- Extremely light weighing under 11 pounds
- Struggles with 6010 rods on 110V
- Cheap quality ground clamp made from thin metal
- Electrode holder not the strongest so I suggest replacing it
- Not recommended for TIG welding
I didn’t expect much from the YesWelder Arc Pro 165A, but it surprisingly impressed me. While it’s also a dual-voltage machine, the 110V output worked pretty well with 6013 and 7014 rods. I struggled to get decent welds with 6010 on 110V, and 6011 rods were slightly better.
This welder features an automatic settings feature where you select your rod diameter, and the machine handles the current settings for you which is a nice feature for newbies.
I wasn’t impressed with the cheap ground clamps and felt the electrode clamp was also a little too cheap, but it’s not really expensive to replace the clamps, and the rest of the machine makes the purchase worthwhile.
This welder can also run TIG process, but you’ll need to purchase a torch, regulator and a few other pieces to add that to your arsenal.
Overall if you’re doing light duty work with 6013 or 7014 rods this machine is a great buy.
3. Forney Easy Weld 100ST 110v Arc Welder
- Weighs just 9.7 pounds
- 10-90 amp output
- 16-gauge sheet to 1/4-inch steel
- Burns up to 1/8-inch rods
- 30 percent duty cycle @ 80 amps
- Runs both 6013 and 3/32 7018 stick rods well
- Great for beginners to learn on
- Extremely compact and easy to carry
- True 110V only model
- Infinitely adjustable current dial
- TIG capable (parts cost extra)
- Struggles to reach the full 90A output
- 8-foot leads are a little short
- Ground clamp doesn't contact well
- Stinger don't hold the rods well and feels cheap
- TIG torch is not included
The Forney Easy Weld 298 Arc Welder 100ST is a great little welder for beginners. At just under 10 pounds and about 12 by 10 by 6 inches, it’s compact and lightweight. For someone without a lot of extra shop space, it’s easy to store and it’s easily carried to get things done around the house.
This is a 110v only machine and the power output tops out at 90 amps, good enough to run 1/8-inch rods. Owners of the Forney Easy Weld 100ST mention smooth welding on 6011, 6013 and 7018 electrodes, although with 7018 it’s recommended that you stay below the 1/8-inch max diameter. Forney suggests running 3/32 rods when welding with 7018.
One of the nice things about the Forney Easy Weld 298 Arc Welder 100ST is its ability to convert to TIG capability, a great feature for this price range. You’ll need to buy parts like an argon regulator and a TIG torch. The only real negatives to this machine are short 8-foot leads, and the grounding clamp has an unusual contact design. These things won’t stop you from welding, and they’re inexpensively fixed.
4. Miller Maxstar 161 S Series Stick Welder
- Dual 110v-240v input
- 13-foot rod connection
- 10-foot ground connection
- Dinse connectors
- 20-160 amp range
- Specific setting for 6010 rods
- Weighs only 13 pounds
- Power factor correction
- Anti-sticking cuts power if stuck
- Lowers voltage when not in use
- Digital controls can give out
- Pricey industrial arc welder
The is a premium professional machine with industrial build quality. It features a specific setting to accommodate 6010 rods, neatly taking care of one of the main complaints with lightweight inverter-type welders. You can be certain you’re able to run 6010 rods and it’s CSA certified, qualified to work on government jobs.
The primary buyers for the Miller Maxstar 161 S Series Stick Welder are professional welders and repair workers. One complaint offered by these users is that the digital controls can wear out or break under hard use. Professionals pay extra money to avoid this kind of problem. For the average DIY shop it’s probably not a major concern.
The Miller Maxstar 161 S Series Stick Welder gives up to 90 amps output on 110 volts, is known for smooth welding and sports a nice anti-sticking feature to avoid problems with sticking electrodes when running low current. This machine also cuts the power if you do get stuck. There’s also a power factor correction feature that yields the same arc characteristics and current level when switching between 110 volts and 240 volts.
Wrapping it Up
We like the Hobart Stickmate 160i as the Best 110v Stick Welder for the money, with a 5-year warranty, dual-voltage input, 6010 rod capability, and the fact that it’s the consistent favorite pick by professional welders in need of a lightweight stick welding machine.
YesWelder’s Arc Pro 165A offers a good alternative to the Hobart Stickmate and provides excellent value if you’re doing light work with 6013 or 7014 rods. It’s also a dual-voltage machine if you need the extra power.
The Miller Maxstar 161 would be my go-to pick if you’re doing more work out in the field on the farm and need to run 6010 rods.
