7 Best MIG Welders Under $1000
Disclaimer: Weldguru.com supports our readers with industry knowledge & research. You support us through our carefully chosen products with links that may earn us a commission.
The past few years have seen many quality MIG welders that used to be about $1000 explode in price.
For example, I remember in 2017 picking up a Miller 211 for about $1000 with a rebate. Now, that same machine is about $2000.
So, finding a good MIG machine under $1000 has become much more challenging.
While it wasn’t possible to test all MIG machines under $1000, I used my experience with the machines I have used, as well as some help from some fellow welders.
When choosing the best options, I looked for:
  • Stable power output
  • How easy it is to find consumables/replacement parts
  • Machine build quality
  • Brand reliability and support
  • Overall user satisfaction
Note: I purposefully avoided the low-end Chinese MIG welders as I have had bad experiences with them. Either they weren’t reliable, the parts were hard to find, or their support was non-existent.
With that in mind, let’s dive in.
Quick Comparison
Img Product Duty Cycle Voltage Processes Screen Controls Where to Buy
Best for beginners
Eastwood 180 MIG
Eastwood 180 MIG
60% at 130A, 100% at 100A 120/240V MIG, Flux-cored None Analog
Best overall
Firepower FP-200
Firepower FP-200
60% at 100A, 15% at 200A 115/230V MIG, Flux-cored Digital Digital
Best value for the money
YesWelder 250A
YesWelder 250A
60% at 250A, 100% at 193A 220V MIG, Flux-cored, Stick, DC TIG Digital Digital
Best multi-process pick
Klutch MP230SiDV
Klutch MP230SiDV
40% at 90A, 20% at 200A 120/230V MIG, Flux-cored, TIG, Stick LCD Digital
Best cheap option
Everlast Cyclone 200E
60% at 90A, 25% at 180% 120/240V MIG, Flux-cored LCD Digital
Best by popularity
Hobart Handler 210 MVP
30% at 150A 120/240V MIG, Flux-cored None Analog
Cheap transformer MIG welder
Lincoln Easy MIG 140
20% at 90A 115V MIG, Flux-cored None Analog
Best MIG Welder Under $1000
Here's some of the best MIG welders under $1000 I recommend:
1. Eastwood 180 Amp MIG Welder
Best for beginners
Eastwood 180
4.5 Weld Guru rating
Weld Guru’s rating is determined by a variety of factors including features, performance, independant research and real user ratings. Scoring is not influenced by the manufacturer.
This welder is a good choice for first-time welders because of its arc quality and low cost. Plus, its ease of use and additional features are beneficial for rookies.
  • Brand:
    Eastwood
  • Model:
    180 MIG
  • Weight:
    25.3 lbs
  • Price:
  • Duty Cycle:
  • Voltage:
    120/240V
  • Processes:
    MIG, Flux-cored
  • Max Thickness:
    Mild steel up to 5/16 in.
  • Screen:
    None
  • Controls:
    Analog
  • Max Output:
    180A
  • Warranty:
    3 Years
The Eastwood MIG 180 is one of my favorite welders for beginners and is one of the best inexpensive welders on the market. Don’t be fooled by the simplicity of this machine. Its build and arc quality impressed me, and it’s not far off the Hobart Handler 210 and Lincoln Easy MIG 140. It beats the Hobart and Lincoln models in my opinion because of the price-to-quality ratio.
It uses the latest IGBT inverter technology, making it lightweight and portable. The added features like 2T/4T modes let you weld without keeping the torch trigger depressed at all times (4T). Plus, the tack welding feature enables you to make consistent tack welds, making it a good choice for sheet metal work.
Eastwood MIG 180 Demo
The Eastwood MIG 180 is great for beginners because it’s inexpensive, has a great arc quality, infinite adjustability, and added features. The combination of these lets you learn how to properly weld on a budget, and from your home thanks to its dual voltage support.
If you are looking for a machine to learn how to weld, don’t buy a random cheap welder with poor arc quality. If you do, you’ll have to re-learn most of the techniques. That’s why this inexpensive Eastwood is a good choice for rookies.
But if you need more power and are willing to sacrifice some portability, the Eastwood MIG 250 can weld up to 1/2 in. thick and remains below $1000.
  • Inexpensive
  • High-quality build
  • USA brand
  • Upgraded with the latest IGBT inverter technology
  • Smooth, stable arc
  • Good duty cycle
  • 2T/4T and tack welding modes
  • Infinite adjustability
  • Native spool gun support for welding aluminum
  • Supports dual voltage input
  • Lightweight and portable
  • 3-Year warranty
  • No display
  • Ground clamps are not the best quality
2. Firepower FP-200 MIG Welder
Best overall
Firepower FP-200
Competing with Hobart and Lincoln lines, this inverter MIG welder from ESAB's brand is excellent value money and can be compared to the ESAB EM 210. is the best MIG welder under $1000, thanks to its exceptional arc and built quality.
  • Brand:
    Firepower
  • Model:
    FP-200
  • Weight:
    28.7 lbs
  • Price:
  • Duty Cycle:
  • Voltage:
    115/230V
  • Processes:
    MIG, Flux-cored
  • Max Thickness:
    Mild steel up to 3/8 in.
  • Screen:
    Digital
  • Controls:
    Digital
  • Max Output:
    200A
  • Warranty:
    3 Years
The Firepower FP-200 is an inverter MIG welder by an ESAB owned brand and is almost identical to the ESAB EM 210. It has an exceptional build and arc quality for the price, and includes many useful features. It’s the best MIG welder overall under the $1000 price tag and is designed for work in construction, automotive, agricultural, and fabrication fields.
The biggest shortcoming of the FP-200 is the low-duty cycle. But this is the case with most high-end welders with a lower price tag. It’s challenging to include useful features and excellent arc quality for a low price. Even so, if your shop handles high-volume thick metal welding, the Firepower’s 15% duty cycle at 200A will not suffice your needs. In that case, the Eastwood MIG 250 is your best bet.
Firepower FP-200 Demo
Asides from a low duty cycle, the welder offers exceptional weld quality, ease of use, and adjustability. The 2T/4T welding modes let you weld in regular or 4T mode that doesn’t require you to keep the trigger pressed at all times. While the MIG inductance and wire burnback time let you modify arc intensity and how long the wire is energized after it stops being fed.
Designed by ESAB and backed by a 3-year warranty, this welder is the best unit under $1000 overall.
  • Firepower is a brand by ESAB
  • Great arc quality
  • Built well like all ESAB welders
  • Dual voltage support
  • Digital display
  • Multiple advanced functions like inductance control, 2T/4T, and wire burn back time
  • Spool gun support
  • 3-Year warranty
  • It doesn’t automatically detect the input voltage. It requires a manual switch
  • Low duty cycle
3. YesWelder 250A MIG Welder
YesWelder 250A
4.0 Weld Guru rating
Lightweight, powerful, feature-rich, multi-process welder with emphasis on MIG welding. Made for hobbyists and provides excellent value for the money.
  • Brand:
    Yeswelder
  • Model:
    250A
  • Weight:
    21.72 lbs
  • Price:
  • Duty Cycle:
  • Voltage:
    220V
  • Processes:
  • Max Thickness:
    Mild steel up to 1/2 in.
  • Screen:
    Digital
  • Controls:
    Digital
  • Max Output:
    250A
  • Warranty:
    1 Year
The YesWelder MIG 250 is a powerful, inverter-based multi-process welder focusing on the MIG welding process. It provides many features for a fraction of the competing models’ cost, making it the best value MIG welder.
With 250A of welding power and a 60% duty cycle, the MIG 250 satisfies the needs of hobbyists but also that of a welding shop. However, since this is an inexpensive welder from a brand known for hobbyist-grade equipment, I wouldn’t be pushing its limits daily.
Yeswelder MIG 250A Pro Demo
It offers a decent build quality for the price. The cast aluminum wire feeding system, digital display, quality MIG torch, and a pretty good ground clamp at this price make it a bargain.
The included lift DC TIG and stick welding are a welcome addition, allowing you to work on more clean projects using TIG or weld dirtier metal outside with stick mode. The YesWelder MIG 250 is easy to use thanks to the large digital display and the infinitely adjustable settings.
It supports the flux-cored wire up to 0.045 in. diameter, which is excellent for high filler metal deposition rates and thick metal welding. This is one of the rare welders that support the 0.045 in. wire at this price. So if you weld thicker metals often, it’s worthy of your attention.
  • Inexpensive
  • Good build quality considering the cost
  • 250A of power with a high duty cycle
  • Supports MIG, stick, and lift TIG
  • Automatic and manual welding modes
  • Digital display
  • Infinite adjustability for all settings
  • Accepts wire up to .045”
  • Lightweight
  • Front panel transparent cover protection
  • Cast aluminum wire drive system
  • 1-Year warranty
  • 220V current input only
  • TIG torch not included
  • Spool/MIG gun switch located inside the unit
  • The wire feeding system is a bit hard to access with fingers because the side panel housing partially covers it
4. Klutch MP230SiDV LCD Multi-Processes Welder
Klutch MP230SiDV
5.0 Weld Guru rating
The included spool gun and LCD with advanced menu settings separate this welder from the crowd. It supports all major arc welding processes and comes with everything included, making it one of the best multi-process welders at this price.
  • Brand:
    Klutch
  • Model:
    MP230SiDV
  • Weight:
    33 lbs
  • Price:
  • Duty Cycle:
  • Voltage:
    120/230V
  • Processes:
  • Max Thickness:
  • Screen:
    LCD
  • Controls:
    Digital
  • Max Output:
    200A
  • Warranty:
    3 Years
If you are interested in other welding processes besides MIG and want to stay in a $1000 range, the Klutch MP230SiDV is probably your best bet. While slightly more costly, it supports many advanced features and includes a spool gun for aluminum. Almost all other brands require purchasing a spool gun separately, adding to the price.
The Klutch MP230SiDV comes in a massive package. Everything is included, and all accessories are of good quality for the price. The foot pedal has an extra-long 26-feet cord, and torch/clamp leads are also long.
Klutch MP230SiDV Demo
Its 200A of power lets you weld up to 5/16 in. thick mild steel at a 20% duty cycle. While better than Firepower FP-200, the Klutch’s duty cycle is still low for high-volume welding. However, a small fab shop or a welding professional who doesn’t often weld thick metals will benefit from this welder, thanks to all of its functions.
Offering the four most essential welding processes with many adjustabilities for each, an LCD, very good build quality, and 3-year warranty, make this one of the best multi-process welders at this price.
  • Very good build quality
  • Offers MIG, Flux-cored, Stick, and TIG welding in one unit
  • It comes with all necessary accessories, including the MIG spool gun and TIG foot pedal
  • Good quality MIG and TIG torch
  • Large LCD screen with multi-language menu support
  • It supports auto settings and allows you to fine-tune the wire feeding speed and voltage
  • IAdvanced functions like 2T/4T, spot, and inductance control
  • 3-Year warranty
  • Low duty cycle
  • DC TIG only
  • It doesn’t officially recommend E6010 stick electrodes
5. Everlast Cyclone 200E
Best cheap option
Everlast 200E
Including an LCD display, auto and manual settings, and a 5-year warranty, at a low price, makes it the best cheap MIG welder in our comparison.
  • Brand:
    Everlast
  • Model:
    200E
  • Weight:
    26.5 lbs
  • Price:
  • Duty Cycle:
  • Voltage:
    120/240V
  • Processes:
    MIG, Flux-cored
  • Max Thickness:
    Mild steel up to 1/4 in.
  • Screen:
    LCD
  • Controls:
    Digital
  • Max Output:
    200A
  • Warranty:
    5 Years
The Everlast Cyclone 200E is an inexpensive MIG/flux-cored inverter welder offering decent arc and build quality for the price. It’s one of the cheapest welders with an LCD, a dual voltage input, and a 200A output.
Its duty cycle of 25% at 180A satisfies the needs of hobbyists and professionals who need a cheap but reliable welder. However, the lack of any advanced functions puts this welder in an entry-level category. Nevertheless, the provided LCD is helpful for beginners because it allows you to read the output values and use the auto “PowerSet” mode for voltage and wire feed control.
Testing the Everlast Cyclone 200E
The welder is built well for the price. It uses a cast aluminum wire feeding system, a good MIG torch, and a decent ground clamp. However, the knurled groove drive roll is sold separately. So, you can’t weld with a flux-cored wire out of the box. Additionally, the back of the welder is rather flimsy. The on/off button, gas inlet, and cooling fan aren’t nearly as well made as with the Eastwood MIG 180 that’s similarly priced.
The Everlast Cyclone 200E is a good machine for the price, but it’s best if used by hobbyists or for light shop welding. The 5-year warranty is impressive. So, unless you push this welder too much, you should get a great return on investment.
  • Inexpensive
  • Good built quality
  • Digital display
  • Lightweight
  • Dual voltage input support
  • Easy to use
  • Spool gun ready
  • Auto and manual modes for voltage and wire feeding settings
  • 5-Year warranty
  • Knurled drive roll for flux-cored wire is not included
  • Duty cycle on the low end
  • It doesn’t support any advanced features like 2T/4T, burnback, or inductance control
6. Hobart Handler 210 MVP
Best by popularity
Hobart 210 MVP
One of the most popular welders for DIY hobbyists, the Handler still keeps its legacy as a machine with the best arc and build quality.
  • Brand:
    Hobart
  • Model:
    Handler 210 MVP
  • Weight:
    79 lbs
  • Price:
  • Duty Cycle:
    30% at 150A
  • Voltage:
    120/240V
  • Processes:
    MIG, Flux-cored
  • Max Thickness:
  • Screen:
    None
  • Controls:
    Analog
  • Max Output:
    210A
  • Warranty:
    3 Years
The Hobart Handler 210 MVP is an iconic welder by one of the best welding machine manufacturers. It’s transformer-based, has a beautiful arc, and has a strong warranty. At the time of its launch, it was one of the best portable welders, but newer technologies provided by other brands have taken its throne.
Hobart Handler 210MVP demo
Today, 79 lbs can’t be deemed portable, even if you can physically move it. Its outdated 7 fixed voltage system is good enough, but infinite adjustability is simply better. It doesn’t have a display and costs much more than welders that do. And to put the cherry on the cake, it integrates the ground clamp and doesn’t use the standard DINSE plugs. This makes polarity change more complicated, and replacing the ground clamp requires rewiring inside the unit.
This is still a very good welder. But it’s definitely overpriced, judging by today’s standards. However, if you want the best build quality, Hobart is still a leader in that arena. Plus, its quick select wire drive may be helpful for people who switch wire spools often. But even if we take all positives into account, welders like Eastwood MIG 180 still provide much better value
  • Excellent build quality
  • Smooth, stable Hobart’s arc
  • USA brand
  • Quick select drive roll for easy wire switching
  • Intuitive front panel interface
  • High maximum wire feeding speed
  • Has a native spool gun support
  • The lowest output of 25A for stock as thin as 24 gauge
  • Best cast aluminum wire feeding system of all welders in the review
  • Hobart’s 5/3/1 warranty
  • Heavy compared to inverter welders
  • Low duty cycle
  • It doesn’t use standard DINSE connectors, requiring you to switch polarity inside the machine
  • Uses outdated fixed-voltage output points instead of the infinitely adjustable knob
  • No display
  • It doesn’t support any advanced functions
  • Integrated ground clamp
  • Relatively expensive compared to other brands
7. Lincoln Electric Easy MIG 140
3.5 Weld Guru rating
If you value old transformer technology and don’t want to get something overly heavy, this welder may fit the profile.
  • Brand:
    Lincoln
  • Model:
    Easy MIG 140
  • Weight:
    54 lbs
  • Price:
  • Duty Cycle:
    20% at 90A
  • Voltage:
    115V
  • Processes:
    MIG, Flux-cored
  • Max Thickness:
    Mild steel up to 3/16 in.
  • Screen:
    None
  • Controls:
    Analog
  • Max Output:
    140A
  • Warranty:
    3 Years
Similar to the Hobart Handler 210 MVP, the Lincoln Electric Easy MIG 140 is slowly being run over by time. But unlike Handler 210, it can still be considered portable. If you are looking for a transformer MIG welder, this model has the least weight and can be used for welding on the go.
It has a low amperage output and a duty cycle, so it’s a good choice for hobbyists and light welding tasks only. Unfortunately, it also doesn’t use the DINSE plugs, making the polarity switch more difficult. In addition, there are no extra features like wire burnback or inductance control, and it doesn’t offer infinite adjustability for voltage either. This means that you won’t be able to perfectly dial in your welds like with the YesWelder, Eastwood, or other welders above.
However, Lincoln Electric is one of the best brands in the welding world, and its welders are built to last. The Easy MIG 140 has a very good build quality for the price, so it’s a good budget option if you don’t need any additional features.
  • USA brand
  • Easy to use
  • Portable
  • Angled cast aluminum wire feeding system for better wire feedability
  • Inexpensive
  • Supports a spool gun for welding aluminum
  • 3-Year warranty
  • While portable, it's heavy for a low amperage 115V welder
  • Low duty cycle
  • Low amperage output for the price
  • No display
  • No additional functions like inductance, 2T/4T, or similar
  • Uses fixed-pints voltage adjustment system
  • The welding gun is a bit cheap
  • Integrated ground clamp and absence of standard DINSE plugs
  • Polarity change requires rewiring the leads inside the welder
The Under-$1000 MIG Buying Guide
The most amazing thing about the 1000-dollar price point is the sheer number of machines on the market.
Here’s how you sort through the chaos to get the right machine in your shop.
Power Needs
110/115/120 Volt Machines
With 120-volt power, you’re limited to about 140 amps, still enough to get a lot done. Most household circuits aren’t capable of just plugging in and running a welder without blowing a breaker. The most common breaker size in American homes is 15 amps. You need at least 20 amps to run a welder, with 30 amps even better.
Related read: 110v MIG Welder Reviews
220/230/240 Volt Machines
If you have a 30-amp dryer circuit that runs on 240, you can plug in a pretty powerful machine and get control and power for that roll cage in your dune buggy and beautiful sheet metal work, actually able to do pro work or earn extra money.
Duty Cycle
Duty cycle is the percentage of 10 minutes you can weld continuously before the welder needs to cool. The Yeswelder MIG 250 is rated 100% at 193A. That means it will run for 10 minutes continuously at 193 amps. At the full 250 amps, that drops to only 6 minutes, probably less before it shuts off to cool down.
Accessories and Other Points to Ponder
  • Spool gun – For welding aluminum, you’ll need a spool gun that mounts near the torch. Aluminum wire is soft and kinks up when fed from the spool position in the cabinet.
  • Repair and maintenance – Chinese machines have attractive pricing, but some use parts unique to that maker. Look for industry standards like Tweco gun parts and European or American connectors.
  • Weight and Size – How hard is it to move the machine around? 60-120 pounds for a 240 machine is common.
  • Warranty – This is both a high-tech device and a heavy tool that may get kicked, knocked over, banged around by other tools and stop working.
Rounding It Up
The best value unit is the YesWelder MIG 250A, thanks to its low price, excellent duty cycle, and multiple useful features. It’s a hobbyist-grade brand, but this welder can be used for shop welding too.
However, Eastwood MIG 180 or the more powerful 250 are a better choice in terms of durability. But if you want the maximum quality in this price range, you should consider the Firepower FP-200.
The Eastwood MIG 180 is the best choice for rookies because it’s the least costly, from a USA brand that offers a strong warranty, and has a great arc quality.
But if you are looking for a multi-process unit, consider the Northern Tool’s Klutch MP230SiDV. It’s relatively inexpensive, considering everything that’s included.
For more MIG machine picks, check out the Best Mig Welder Overall
