On this page: Participating Welding Retailers | Best Welding Helmet Deals | Welding Machines Deals
Here are some retailers running Black Friday deals on welding equipment.
Yeswelder
Yeswelder has become an increasingly popular go-to brand for casual welders as their range and spec offer excellent value. They produce their own helmets, which have become top sellers, and their own MIG, TIG, Multi-process & Plasma cutting machines.
They are running their Black Friday & Cyber Monday sale with an impressive 15% off sitewide!
No need for any codes. Just follow the link below to get access to this offer.
Eastwood
Eastwood specializes in auto tools and produces excellent value MIG, TIG, Multi-process welders, and plasma cutters – most of which have been updated for 2022.
Most of these upgrades now make Eastwood better value than popular Hobart and Lincoln machines. They also sell other welding equipment like welding carts and helmets.
Eastwood Black Friday Deals Eastwood Welding Helmet DealsNorthern Tool
Northern Tool sells Hobart, Lincoln, and Firepower (ESAB brand) welders. So if you are after one of these brands, you should be able to find a good deal here.
MIG & Flux Core Welders Stick WeldersAmazon
What doesn’t Amazon sell? Amazon and its retailers are running discounts on a wide range of welding equipment. You’ll get exclusive discounts if you’re a Prime member.
I found some deals on welding helmets and welders that you can check below:
MIG Welders TIG Welders Stick Welders Welding HelmetsBlain’s Farm & Fleet
Blain’s is a stockist of Hobart and Forney welders and is currently running discounts and offers on these machines.
They also offer discounts on various welding equipment, such as helmets and accessories.
Best Black Friday Welding Helmet Deals
- LARGE VIEW WITH TRUE COLOR CLARITY: See more of the weld puddle, joint edges, and work position through a wide 3.93" x 3.66" viewing area. The 1/1/1/1 true-color optical clarity provides a clearer, more...
- FAST AUTO DARKENING WITH 4 ARC SENSORS: Built with 4 arc sensors and a 1/30,000-second switching speed to support responsive shade adjustment across routine welding tasks. Designed for TIG, MIG, Stick...
- VERSATILE SHADE CONTROL FOR DAILY SHOP USE: Adjustable DIN 3/5-9 and 9-13 shade settings give you flexible switch between multiple processes with one helmet. A practical choice for home garages, repair...
- LIGHTWEIGHT COMFORT WITH REINFORCED DAILY-WORK FIT: At approximately 1.32 lb (600 g), this welding helmet is designed for a lighter feel and better balance during longer sessions. The adjustable headgear...
- CHEATER LENS COMPATIBLE WITH EASY POWER SETUP: Compatible with magnifying lenses for improved close-up visibility when needed. Powered by an accessible CR2450 lithium battery and designed to keep setup and...
- Advanced Eye Protection with Blue Light Blocking Technology: This welding helmet features cutting-edge Blue Light Blocking outer lens, shielding your eyes from harmful blue light during welding, protects...
- Panoramic LARGE VIEW: The welding hood is equipped with a 3.94" x 3.23" Large View with Side View (DIN5, non-auto-darkening) featuring 1/1/1/1 optical clarity lenses and True Color technology
- MULTI-PROCESS: Features a versatile Shade Range (3/5-9/9-13), perfect for Professional Welding(TIG, MIG, MMA), CUT and GRIND. Covers most processes with precision protection. Easily accommodates Magnifying...
- Fast Auto-darkening: This auto darkening welding helmet features 4 Arc Sensors for reliable arc detection, ultra-fast switching (1/30000 sec), and adjustable Sensitivity and Delay controls for perfect...
- Comfortability & Durability: Pivot style headgear ensures superior comfort, a secure fit, and balanced weight for all-day wear. Reinforced PP Materials with thicker design ensure exceptional durability and...
- Revolutionary shell design - high impact resistance nylon.
- Halo headgear - ergonomic, infinitely-adjustable 5 point head gear provides extreme comfort and balance. Low-profile design, central pivot point allows for maximum head clearance while helmet is in the up...
- 3.93 x 2.36 in. (100 x 60 mm) viewing area. 1/1/1/2 –5-13 ADF.
- Color touch screen control panel with 8 separate memory settings and externally activated shade 4 Grind Button.
- Hard hat adapter option available for use with ESAB hard hat (excluding Canada).
- Panorama field of vision offers a 6 times larger field of vision than standard welding helmets - and is still a lightweight at only 550 g.
- True Color View - specially developed UV/IR filter allows the realistic color perception typical of optrel, bringing color to the welder's world.
- Autopilot - Detection of the arc brightness and fully automated shade level adjustment from 5 to 12. * If preferred, the Autopilot can be deactivated for manual shade level selection.
- Multi-sensor detection - The completely redesigned controls of the 5-sensor array ensure the perfect regulation of the auto-darkening filter.
- State-of-the-Art power technology - With its rechargeable power-pack, changing batteries is no longer necessary.
- IMPROVED OPTICS — 9100XXi Auto Darkening Filter enables more realistic colors to be visible for welders. See your welds and welding pool with more precision, contrast and natural-looking colors
- FAST AND EASY ACCESS — External welding helmet controls enable grinding and memory modes using 9100XXi silver front panel without removing your gloves
- TWO MEMORY MODES — Allows a welder to set individual auto darkening filter settings for darkness shade, light-to-dark switching sensitivity and dark-to-light delay with the push button access
- AUTO-ON TECHNOLOGY — Allows you to grab their welding helmet and get to work quickly by turning to the last setting used
- EXPANDED PERIPHERAL VISION — Side windows enable a large field of vision making potential hazards such as obstacles and coworkers more visible
Here are some Black Friday welding machine deals I found:
MIG Welders
| # | Preview | Product | Rating | Price | |
| 1 |
YESWELDER 135A MIG Welder, 110V Flux Core Gasless MIG/Lift TIG/Stick... | $149.99 $99.99 | Get this deal | |
| 2 |
ARCCAPTAIN 165A MIG Welder 110V 220V 4-in-1 Gasless Gas MIG Stick Lift... | $229.99 $189.98 | Get this deal | |
| 3 |
YESWELDER 160A MIG Welder, 110V/220V MIG/Flux Core/Lift TIG/Stick | $225.99 $149.99 | Get this deal | |
| 4 |
YESWELDER 205A MIG Welder, 110V/220V 5-In-1 MIG/Flux Core MIG/Spool... | $479.99 $339.99 | Get this deal | |
| 5 |
Futelo 145A MIG Welder, 110V 3-in-1 Flux Core Stick Lift TIG, 7.5 lb | $69.98 $62.98 | Get this deal |
TIG Welders
| 1 |
Weldpro 200A AC/DC TIG Welder with Pulse, 110V/220V Dual Voltage... | $699.99 $664.99 | Get this deal | |
| 2 |
TOOLIOM 135A 110V Stick Welder Kit with Lift TIG Torch, rods & Gloves | $99.99 | Get this deal | |
| 3 |
YESWELDER 205A Tig Welder Pulse STICK/DC TIG/PULSE TIG 3 in 1 TIG-205P | $237.99 $219.99 | Get this deal | |
| 4 |
Sunstac 250A Aluminum TIG Welder with Pulse ACDC Foot Pedal Control | $399.99 $379.99 | Get this deal |
Plasma Cutters
| 1 |
ARCCAPTAIN 50A Plasma Cutter Machine, 110V/220V Dual Voltage, 2/3" Max... | $249.99 | Get this deal | |
| 2 |
Bestarc Plasma Cutter Machine, Pilot Arc, 50A IGBT 110V 220V Dual... | $249.99 | Get this deal | |
| 3 |
ARCCAPTAIN 55A Plasma Cutter Machine, Non-Touch Pilot Arc, 120V/240V | $279.99 $219.99 | Get this deal | |
| 4 |
ARCCAPTAIN iControl CUT55 Pro Plasma Cutter Machine, 55Amp, 120V/240V | $369.99 $269.97 | Get this deal | |
| 5 |
Bestarc 50A Plasma Cutter Machine, Pilot Arc, IGBT 110V/220V Dual... | $269.99 $149.99 | Get this deal | |
| 6 |
50A Plasma Cutter Machine, Pilot Arc, IGBT 110V/220V Dual Voltage | $179.99 | Get this deal |
