The Hobart Handler 210 MVP is a powerful, dual voltage MIG welder. When it first launched, it was one of the best buys for hobbyists and professionals.
The combination of features found in the 210MVP makes it a good fit for small to medium-sized shops. In fact, you may have run across one or two in use. That is due in part to Hobart’s heritage as a welding manufacturer, and the 210MVP comes with their strong 5/3/1 warranty.
However, it is slowly starting to lose its place as the best MIG welder in this price range. It uses older transformer technology, weights too much, and misses many advanced functions competing brands offer at lower prices.
In this article, you’ll learn about its pros and cons. But we will also provide alternatives that offer more power and features with similar build quality and a strong warranty.
Quick Overview of the Hobart Handler 210MVP [500553]
- 10 ft. (3m) HR-100 gun
- 10 ft. (3m) work cable with clamp
- Built-in gas solenoid valve and dual-gauge regulator with gas hose
- Spool hub assembly accommodates 4 or 8 in. spools
- Sample spool of .030 in. self-shielding flux-cored wire
- .030 (0.8mm) contact tips
- Quick Select™ drive roll for .024 in. (0.6 mm) or .030/.035 in.
- Power cord with 5-15 P (115 V, 15 A) and 6-50 P (230 V, 50 A) MVP (TM) plugs
- Welding guide
- Material thickness gauge
- Owner’s manual
Technical Specifications
Manufactured | USA |
Welder Type | MIG, Flux Core |
Input Voltage | 115 V 230 V |
Technology | Transformer based |
Duty Cycle | 20% @ 90A (115V) 30% @ 150A (230V) |
Amperage Output | 25 – 140A (115V) 25 – 210A (230V) |
Voltage Settings | 4 Fixed Positions (115V) 7 Fixed Positions (230V) |
Weldable Materials | Mild and stainless steel, Aluminum |
Torch Lead Length | 10 ft. |
Ground Cable Length | 10 ft. |
Mild Steel Thickness (Single-pass) | 24 ga. – 3/8 in. |
Aluminum Thickness | 18 ga. – 1/4 in. (w/ spool gun) |
Wire Thickness | 0.023 – 0.035 in. (steel) 0.030 – 0.045 in. (flux cored) 0.030-0.035 in. (aluminum) |
Wire Feed Settings | Infinite between min. and max. |
Wire Feed Speed (“WFS”) | 40 – 770 IPM |
Wire Spool Sizes | 4-in., 8-in. |
Spool Gun Ready | ✅ |
Welder Dimensions (H x W x L) | 12.375 in. x 10.625 in. x 19.5 in. |
Weight | 79 lbs. |
Warranty | 5/3/1 years |
Price | Price on Northern Tool (with free delivery) — Price on Amazon |
The Good & Bad
- Puts out 210A, can weld ⅜ in. steel in one pass
- Beautiful Hobart’s arc quality
- Sturdy and built to last
- Goes down to 25A for stock as thin as 24 gauge
- Simple to learn and use
- All metal wire feed mechanism
- Infinite wire speed control
- Spool gun ready handles up to ¼ in. aluminum
- Simple, toolless wire size changes
- Weld settings chart on the inside of the wire compartment door
- Advanced electronic circuity protection
- Strong 5/3/1 warranty
- One of the heaviest “portable” MIG welders in the 200A power range
- Significantly lower duty cycle than competing models
- Switching from MIG to flux-cored welding requires opening up the side door and rewiring the polarity
- It doesn’t use standard DINSE sockets, which is not acceptable at this price
- The ground clamp lead is integrated
- No digital display
- It doesn’t offer infinite voltage adjustability, making it impossible to perfectly dial in the weld in every situation
- It misses useful features like 2T/4T that competing brands include
- Not for those who weld thick (i.e. over 1.4 in.) aluminum
Where you can buy the Hobart 210
Like many Hobart welders, they are available from a range of retailers. Each retailer runs deals from time to time, so it is worth checking where has the current best deal:
- Northern Tool – Great price with free delivery
- Blain’s Farm & Fleet – Free delivery
- Tractor Supply
- Amazon
What You Should Know Before Buying the Handler 210 MVP
Portability/Weight
The Hobart 210 MVP is a bit difficult to move around given that it weighs almost 80 lbs. It is possible to transport because it’s not a massive transformer like Hobart Ironman 240 that’s truly not portable. However, the Hobart 210 is too heavy for today’s standards to be considered portable.
Many other brands offer similar models with a much lower weight. The transformer core does add to the longevity, but if you value portability, you should consider alternatives.
Duty Cycle
The Hobart’s duty cycle of 20% at 90A with 150V input and 30% at 150A with 230V input is good enough for hobbyists. But this is not really a cheap welder, so I wish it provided at least 50% at 150A.
One of the competing models cheaper than the Hobart 210, has a 60% duty cycle at 250A, and it doesn’t lag behind in other areas either (we’ll cover it later in the article). That’s why I wrote earlier that the Hobart 210 is losing its place at the top. Such low specs are not the standard anymore.
Fixed Voltage Settings
With its seven fixed voltage output points, Hobart 210 will offer pretty good adjustability. At the time of its release, this was exceptional. Today, it’s outdated. Many brands provide infinite voltage output adjustments, allowing you always to tune your welds perfectly.
Hobart knows this. That’s why they updated their Ironman 230 to 240 model and switched from fixed voltage points to infinite adjustments. I hope they’ll upgrade their iconic Hobart 210 as well. But, until then, brands that offer this level of arc control have the edge over this Hobart model.
No DINSE Connectors For Polarity And Ground Clamp
While Hobart 140 could pass as a cheap hobby welder, the 210 MVP is relatively costly. It’s certainly expensive enough to support standard DINSE plugs, right?
Well, unfortunately, the Hobart 210 has an integrated ground clamp and no DINSE plugs. Hobart’s Multi-Handler 200 certainly uses them, and so does their Stickmate 160i, so why didn’t their MIG 210 get the same treatment? If there are no DINSE plugs and the ground clamp is integrated, the process of switching polarity is more complicated. Instead of just plugging and unplugging the connector, you have to open the wire spool compartment and rewire the polarity for flux-core or MIG welding.
Spool Gun not Included
We are not complaining that the spool gun is optional for the price. But we felt it should be added here to let you know; if you plan on welding aluminum, you need to buy the spool gun separately or buy the package with the spool gun – as this is cheaper.
Also, with the spool gun, you can weld up to ¼ in thick aluminum. That may be thin for those who do a lot of aluminum fabrication work.
Best Features of The Hobart 210 MVP
Ease Of Use
Look at the control panel, and what do you see? Two knobs and an on/off switch. That’s it. One dial sets the voltage, and the other sets the WFS.
Setup for this welder takes seconds, and you would be hard-pressed to find one that is easier to use. There is even a thermal overload light that comes on when you trip the thermal protection. Again, convenient as you wait till the light goes out to start welding again.
Output Power
Do not assume because this welder is easy to set up and use means that it has no power. It puts out 210 amps and can weld ⅜ steel in one pass. For many shops, that is all they need.
Yes, if you are welding up army tanks, ⅜ will not be thick enough. But for most of us, the power in this unit is plenty. But, if you must weld thicker than that, our alternative pick can weld up to 1/2 in.
Voltage Input
The 240V wall plug can be a bane to some shops. It is not always easy or affordable to run a high voltage line/plug into your shop. When you have to go to mobile, that becomes even more of a problem. The odds of a 240V plug being where you need it are almost nada.
But with the 210MVP, you can use 120 or 240 volts to run the unit. The MVP plugs swap out in an easy-to-use system. Just unscrew the retaining nut at the base of the plug, swap in the new plug, and tighten the retainer nut.
No wall outlets at all? No problem for the Handler 210MVP. It can also run on generator power. (Hobart recommends a minimum of 6000 continuous watts of output power.)
Wire Feed Mechanism
One of the things Hobart became known for is its QuickSelect wire feed system. They constructed the mechanism from all metal parts and made it simple to change the roller for different wire sizes, using only your fingers.
This wire feed setup works well. So well, in fact, many users comment how surprised they are with how easily and reliably it works.
Welds Aluminum
“Affordable” MIG welders often cannot accept a spool gun. But the Hobart 210 MVP comes with the electronics built-in and the port ready to receive one.
It gives you the ability to weld ¼ in. thick aluminum in a single pass when you add the optional spool gun.
Alternatives To Consider
While we respect what Hobart has achieved with their iconic Hobart 210 MPV, we have to point out that there are welders with better specs today. We hope Hobart updates the 210 model eventually, but it doesn’t offer the best value for the money for now.
The two best models for comparison are Eastwood MIG 250 and 180. The Eastwood 250 offers more power, and it’s just slightly cheaper than Hobart, while the 180 model is significantly cheaper but has less power than Hobart.
The Eastwood MIG 250
The Eastwood MIG 250 is a dual-voltage inverter MIG welder capable of welding 1/2 in. thick steel in a single pass. It’s backed by a 3-year warranty and has a similar arc and build quality as Hobart.
The impressive 250A output coupled with a 60% duty cycle lets you weld thick elements for a long time. This welder is meant for professional applications. The 100% duty cycle at 194A means that you can weld indefinitely the same thickness as Hobart, allowing you to run a serious welding shop.
It supports infinite voltage and wire feeding speed adjustability, giving you much better adjustability than Hobart. Additionally, it does use standard DINSE plugs, making the polarity change effortless.
The welder is lightweight and portable at 46 lbs. It comes with a high-quality Trafimet ERGOPLUS24 MIG torch and a heavy-duty ground clamp.
Unlike Hobart 210, the Eastwood 250 includes some helpful functions like 2T/4T, tack welding mode, and a quick feed button. The 2T/4T lets you switch between standard (2T) and a four-touch (4T) mode that lets you weld without holding the MIG gun trigger. This is especially useful considering its extreme duty cycle. You can weld long welds without getting hand fatigue or hitting the duty cycle.
The tack welding mode lets you make consistent tack welds regardless of how long you keep the trigger depressed. This is helpful for sheet metal work and when modifying car body parts like fenders.
The Eastwood 250 is cheaper than Hobart 210, has a 3-year warranty, and has a similar build quality. With its 250A, impressive duty cycle, and helpful features, it’s definitely worth your attention, which is why we had to compare it head to head with Hobart.
Eastwood MIG 250 | Hobart Handler 210 MVP | |
Technology | IGBT Inverter | Transformer |
Weldable Mild Steel Thickness | Up to 1/2 in. | Up to 3/8 in. |
Amperage Output | 50-250A | 25-210A |
Duty Cycle | 60% at 250A 100% at 194A | 30% at 150A 15% at 200A |
DINSE Sockets | ✅ | ❌ |
Integrated Ground Clamp | ❌ | ✅ |
Infinite Voltage Adjustability | ✅ | ❌ |
2T/4T | ✅ | ❌ |
Tack Weld | ✅ | ❌ |
Weight | 46 lbs | 79 lbs |
Warranty | 3-Years | 5/3/1 |
Price | $$ Best Price Eastwood | $$$ Price on Northern Tool (with free delivery) — Price on Amazon |
The Eastwood MIG 180
The Eastwood MIG 180 costs less than half of Hobart 210. Its maximum output is 180A, 30A less than Hobart, but its duty cycle is significantly higher. Additionally, it’s three times lighter and supports all advanced features as its bigger brother, the Eastwood 250.
We wanted to provide a cheaper alternative in case you don’t need the full welding power of Eastwood 250 or Hobart 210. Below is a full comparison table.
Eastwood MIG 180 | Hobart Handler 210 MVP | |
Weldable Mild Steel Thickness | Up to 5/16 in. | Up to 3/8 in. |
Amperage Output | 30-180A | 25-210A |
Duty Cycle | 60% at 130A 100% at 100A | 30% at 150A 15% at 200A |
DINSE Sockets | ✅ | No |
2T/4T | ✅ | ❌ |
Tack Weld | ✅ | ❌ |
Weight | 25.3 lbs | 79 lbs |
Price | $ Best Price Eastwood | $$$ Price on Northern Tool (with free delivery) — Price on Amazon |
For an easy-to-use, reliable MIG welder with 210A of power, the Hobart 210MVP is still a good option.
But as welding technology advanced, other brands started providing more for a lower price.
The Eastwood welders are the best examples of reliable machines that have a significant edge over Hobart at this price range.
If you have any experience with the Hobart 210, please let us know your thoughts in the comments below.
Can’t argue with any of the facts in this review but a lot more needs to be taken into account. Hobart is Miller quality, made in the USA for the well-to-do DIY.
Eastwood is a Chinese made, mass-produced inverter welder labeled for Eastwood.
The spot weld feature is awesome and the duty cycle is killer but it will never last like a Hobart.
That extra 47 lbs is a copper transformer you are paying for, that if kept clean of contaminants and kept out of the elements, will last the lifetime of its owner and possibly his kids too.
Then there is the Spool gun… Hobart comes with the Miller spool gun which rolls like a dream, while Eastwood comes with a cheap generic plastic unit that reviewers on their own site claim is so bad it is unusable.
Warranty: Hobart/Miller can be dropped off at a depot in just about every town in North America. Unless you live around one of the five Eastwood warehouses, you will have to ship out your welder for repair.
Spares: How long will you be able to get Spares to have your Eastwood Service out of warranty? Depends on the mood of the Chinese company that makes them for Eastwood.
The Hobart is a sure thing, not as feature-rich but known to lay down the best welds in the industry.
Hi Claude, thanks for your reply.
Inverters have come a long since they were first introduced to welders and have become increasing more reliable. Miller are using them in some of their machines too like the Millermatic.
Inverters are great for hobbyists and professionals if you are working in normal environments. You can also get better arc stability with with the hardware and software to control it.
An inverter still has its place, as you mention, they are great if you are working in harsher conditions and will most likely outlast most inverters. I have another article on transformers vs inverters here for a more in depth comparison.
With the warranty: While Eastwood and Hobart have the same length, you make a great point about the ease of dropping it off – if you ever need to.
With the spares: Eastwood using industry standard contact tips. Anything else you need is covered under warranty. Eastwood have also been helpful in sourcing parts if needed.
I know alot of people are loyal to the Hobart machines and I can’t argue that they are not great – they are pretty robust! However, it’s worth noting the latest options on the market.
Hi William – most new inverters have protection systems to stop any damage from happening.
